CompileFolderCore: error 8
I'm getting the error message "CompileFolderCore: error 8" for several libraries (llb files) when doing a mass compile. Can't find any clues in LV Help or in the Knowledge Base.
Any help will be appreciated. Thank you!
(4,226 Views)
Found the error code description:
LabVIEW:  File permission error. You do not have the correct permissions for the file.
The mass compile can't proceed on a read-only library.
(4,222 Views)
Hi Homiachok,
Is your .llb file read only? The error is pretty specific that you cannot mass compile a read-only library.
Nick R
NI
(4,211 Views)
Yes, Nick, that's what the problem was. Once I've made the library writable the message went away. So this was an easy one! :^)
Thank you!
(4,206 Views)
