Compare date and time between two text files
Hello everybody,
It's the first time I publish a question on the forum but I don't find any answer on internet.
I have Labview 2019.
My aim is to compare two text files.
         First file (date time; value 1;value 2;value 3)
         Second file (date time; value 4;value 5;value 6)
I want to create a new text file
         New one (date time;value 1;value 2;value 3;value 4;value 5;value 6)
The following  VI works for few amount of data. But I may have  more than 10000 values.
I join you my VI.
You need to enter on the first file link the HOBO file and on the second the RBR file and change the enum to RBR.
If I am not clear tell me.
PS: I know my VI is not very clean.
Thanks a lot,
Adrien Bonnefoy
(1,752 Views)
Your code is hard to read; it's bigger than my monitor.
It's not clear what you want to do.
From the HOBO-2 File:
Titre de tracÈ : 20794806;;;
Date;ConductiviteLR;ConductiviteHR;Temperature
08/07/2022 05:30:00;0.9;0.8;22.51
08/07/2022 05:30:07;1;0.8;22.52
08/07/2022 05:30:08;2.3;0.8;22.52
08/07/2022 05:30:09;1;0.8;22.52
From the RBR-2 file:
Time;Pressure;Sea pressure;Depth
08/07/2022 05:30:00;10.19203465;0.059534648;0.059049164
08/07/2022 05:30:01;10.19192678;0.059426776;0.058942172
08/07/2022 05:30:02;10.19180169;0.059301695;0.058818111
08/07/2022 05:30:03;10.19187774;0.059377743;0.058893539
08/07/2022 05:30:04;10.191966;0.059466002;0.058981078
08/07/2022 05:30:05;10.19213271;0.059632713;0.059146429
08/07/2022 05:30:06;10.19243672;0.059936715;0.059447953
08/07/2022 05:30:07;10.19204445;0.059544454;0.05905889
It looks like RBR has time every second, but HOBO has gaps.
What do you want to do with those gap cases: where one file has data at 5:30:01 and the other doesn't?
I presume you need to time-align the data.
If that is correct, then
Open both files
Skip header line(s)
Create Result file.
repeat
   Read line from HOBO
   Convert column 0 to TIMESTAMP  (Th)
   Read line from RBR
   Convert column 0 to TIMESTAMP  (Tr)
   Repeat
       If Th < Tr
            Read Line from HOBO
       if Th > Tr
            Read line from RBR
       until (Th = Tr) or EOF
       if not EOF
           Extract Columns from HOBO and RBR lines
           Format new RESULT line
       end
until EOF
That will skip unmatched lines (in your example, that would be 5:30:01 to 5:30:06)
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
(1,723 Views)
Accepted by adri73
You were not far from succeeding.
Here is a cleaner, working solution that better uses loops, clusters and arrays.
Well actually that could almost be a CLD exercise 😉
Cordialement,
Raphaël.
(1,712 Views)
Hi guys,
Thanks for your quick answer.
I will look at your solution as soon as possible.
I know my code is very well constructed but I am a beginner with Labview (2 years).
I will let you know when I will succeed.
Adrien
(1,694 Views)
Hi Raphael,
I would like to thank you. I upgrade the code that ou sent to me, to match with my need and it's work very well.
I will try for my next code to make them more cleaner.
Adrien
(1,633 Views)
