in-place for two clusters
Hi
I am not sure about the in-place thing, how it works... I have a big array of clusters and I am making some calculations and put them in another array of clusters. How do I use the in-place thing to decrease memory use ?
When I add cluster at input in the in-place structure, the outside request the same cluster
Thanks for any ideeas
Regards
(1,126 Views)
Hi nitad,
So you have two inputs and two outputs…
Have you tried exactly this?
(1,124 Views)
You gave me an ideea, but let me check if this is correct...
One of the inputs will be a constant and one of the outputs will not be used.. is that it ?
thanks
(1,122 Views)
Accepted by topic author nitad54448
Hi nitad,
When the output is not used then you don't need the IPE structure for this array/cluster…
And the other input will be a constant!? Why do you need the IPE at all when you want to replace some entries in a constant array of clusters?
(1,110 Views)
one of the outputs is not used in this vi, but is a part of a bigger cluster (and there some arrays calculations I don't need to copy the data for)
I did what you suggest, let me test, I'll tell if it's better, or not
regards
(1,098 Views)
