CompactDAQ Controllers
Hello.
I am looking for a system that can take input 220V, thermostat input and can execute the output as we make on labview.
On your website most suitable one is CompactDAQ cDAQ 9171 along with C series temperature controller module NI 9210.
I wanted to confirm that whether CompactDAQ cDAQ 9171 will be able to meet my requirements or not?
Can you suggest any other suitable system ?
(2,381 Views)
Hello Mahrukh
The cDAQ 9171 you have opted has one slot and it is sufficient for C series temperature controller module (any standard Thermostat input) but make sure that you don't need any other Analog Inputs/Outputs or Digital IO.
Hope this helps!
-Rahul
Hit KUDOS for Thanks
(2,358 Views)
