Compact Rio
Is it possible to connect compact rio embedded controller to the moniter display.
(4,118 Views)
Hi Hernant,
you can connect your cRIO to a monitor using some wires, it's physically possible.
Would it be useful, when your cRIO doesn't provide a monitor output? No…
(Using some high-speed analog outputs you could fake a VGA signal. Quite some effort, but used for some emulator hardware for old game controllers.)
(4,114 Views)
Why it's not  useful to have moniter output.
Do you have any connection diagram to connect to moniter?
Hemant
(4,111 Views)
A Compact RIO is an I/O controller that includes some on-board processing capabilities to facilitate I/O and allow some control loops to run independently from the main LabVIEW code (running on a PC) that has the User Interface.  It is this "Main" routine that can acquire data via the cRIO and produce the displays that you need -- the cRIO is best thought of as an I/O controller, though one that can handle some processing and Control Loop chores without involving the calling PC.  To put Display processors on this specialized I/O controller would vastly complicate its architecture, and undoubtedly cause a significant speed penalty.
(4,099 Views)
The cRIO-903X series have Display Port capability and you can enable the embedded display.  This does take resources away from your application and may introduce jitter and resource exhaustion.
(4,082 Views)
As others have said - some of the CompactRIO chassis have display options (e.g. DisplayPort etc.) so you can connect them to a monitor although I don't think this is used very often.
More commonly, you would write a separate PC application to act as your user interface which communicates with the CompactRIO to send/receive data/commands from the user. You could also use something like Web Services / WebSockets to provide a web-based interface to the CompactRIO.
(blog)
(4,053 Views)
