Communicate with Delta PLC (DVP28SV) using Labview over TCPIP ethernet
I want to communicate with a Delta (DVP-28SV) PLC over TCP/IP Ethernet using Labview.
Labview does have a OPC server (with SCADA module) but I do not want to use it.
Ram Prakash
(8,526 Views)
Here is supported device list : http://zone.ni.com/devzone/cda/tut/p/id/6417
Starting point for OPC Server :  http://zone.ni.com/devzone/cda/tut/p/id/7450
(8,512 Views)
thank you for your response but I want to do this without using an OPC server.
(8,493 Views)
My Mistake.
In this case, you can use Modbus Library for ethernet or serial interface to communicate with PLC.
http://zone.ni.com/devzone/cda/epd/p/id/4756
(8,489 Views)
Hello Everyone,
                              Me having a question Can we able to communicate with Delta PLC without Lookout server is it possible, i need a direct Communication between Labview and PLC Using TCP/IP
If Possible please help me ......Smiley Indifferent
(7,035 Views)
if you knowned how Communicate with Delta PLC (DVP28SV) using Labview over TCPIP ethernet tell me
(6,127 Views)
