Comment
Hi all,
This might be silly but I am unable to comment on the whitespace anymore.(Labview) It was working fine 5 minutes ago and suddenly it stopped working. Any ideas why?
(3,356 Views)
Hi ms6,
@ms6 wrote:
Hi all,
No.
But you might attach your Vi when you have problems with your VI…
(3,320 Views)
Thanks for taking out the time but that has been resolved !:)
(3,308 Views)
Hi ms6,
This forum works best when the answer is not just "has been resolved", but provides an explanation/solution for others with the same problem…
Mind to share your solution?
(3,304 Views)
Accepted by topic author ms6
I just restarted my laptop.
(3,298 Views)
Could it have been that you actually accidentally turned off automatic tool selection?  That would make it so you would have to manually select the text cursor to place a label.  If you tried using the default arrow, it would act like creating a free label no longer worked...
Bill
CLD
(Mid-Level minion.)
(3,270 Views)
I checked just now, automatic tool selection is in place.
(3,234 Views)
