Writing waveform to TDMS File
I'm trying to write acquired data to TDMS file.
Code as below works very well: Data from random source is written to TDMS file
When I try to use Waveform as input for TDMS Write.vi - there is nor error and no result for TDMS file:
What is the reason if no adding data to TDMS file?
Thank You for tips
(1,958 Views)
Accepted by topic author Tom_wolf
In a waveform, "dt" is just the time between points.  You need to actually add some data to the waveform in the Y array:
(1,942 Views)
