Comment
Hi all,
This might be silly but I am unable to comment on the whitespace anymore.(Labview) It was working fine 5 minutes ago and suddenly it stopped working. Any ideas why?
(3,340 Views)
Hi ms6,
@ms6 wrote:
Hi all,
No.
But you might attach your Vi when you have problems with your VI…
(3,304 Views)
Thanks for taking out the time but that has been resolved !:)
(3,292 Views)
Hi ms6,
This forum works best when the answer is not just "has been resolved", but provides an explanation/solution for others with the same problem…
Mind to share your solution?
(3,288 Views)
Accepted by ms6
I just restarted my laptop.
(3,282 Views)
Could it have been that you actually accidentally turned off automatic tool selection?  That would make it so you would have to manually select the text cursor to place a label.  If you tried using the default arrow, it would act like creating a free label no longer worked...
Bill
CLD
(Mid-Level minion.)
(3,254 Views)
I checked just now, automatic tool selection is in place.
(3,218 Views)
