Command PUTTY without user intervention
Hello everyone,
In a project I want to create a VI witch can send a command via PUTTY.
For that I think I need to :
 - Open a putty window (done)
 - Write a simple command, like O2E (because of a code than I download, putty will understand it)
 - And finally, close the putty windows to be ready for the next command
If you have any idea or link which can help me, please share them.
It is realy simple but i add my LabVIEW code.
Have a nice day and thanks for your time
Vincent.
Message 1 of 20
(7,353 Views)
Your Putty install should come with a command line interface (plink.exe).  Use System Exec in LabVIEW to pass commands to the Putty interface and read the results.  System Exec command line input will be something like this:
cmd /c plink.exe -ssh -batch -pw yourPassword yourUsername@yourIPorMachineName date
Specify the working directory input as the directory that plink.exe is located in.  The -batch option will allow bypassing of user prompts automatically.  If the command works that standard output should return the system date, assuming this is a Linux RT target.
PLink doc:
https://the.earth.li/~sgtatham/putty/0.75/htmldoc/Chapter7.html#plink
Message 2 of 20
(7,347 Views)
Which port are you connecting to? Is it possible to simply establish the TCP connection directly from LabVIEW and send your commands directly?
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 20
(7,300 Views)
Use a VISA Resource.  There is nothing PUTTY can do that VISA can't
"Should be" isn't "Is" -Jay
Message 4 of 20
(7,289 Views)
I'm curious.  How would you do SSH on VISA?
Bill
CLD
(Mid-Level minion.)
Message 5 of 20
(7,285 Views)
Directed specific to SSH Maybe wrong.
Putty doesn't afaik
A tcp/ip raw socket can I thought
Message 6 of 20
(7,280 Views)
Putty doesn't afaik
I'm asking because I have a bunch of plink commands that I would love to change over to native LV code.
Bill
CLD
(Mid-Level minion.)
Message 7 of 20
(7,256 Views)
LabVIEW 2020 should support ssh, at least using the TCP primitives. The other alternative would be to use stunnel along with the native TCP primitive.
Mark Yedinak
LabVIEW Champion
Message 8 of 20
(7,238 Views)
@billko wrote:
Putty doesn't afaik
You could start that thread
Message 9 of 20
(7,233 Views)
Use PUTTY is a must in my project.
The code is for an amplifier specially made for us and the engineer who made it told us to use PUTTY.
Thank for your subjection.
Message 10 of 20
(7,178 Views)
