Combine For Loops
Hi neebie here,
This is my first message in the forum. Is it possible to combine these for loop as one?
(3,957 Views)
Accepted by Raj_Kumar23
I would sstongly suspect that it could be done
"Should be" isn't "Is" -Jay
(3,939 Views)
I think instead of asking how two loops can be combined, you shoud instead tell us how you want to precess the input array and what kind of result you want. Maybe there is a much simpler solution to all of this.
I don't quite understand your use of the time. Why do you have diagram constants such as 8:00, but then you are disregarding the minutes completely.
(3,925 Views)
A Look at the excellant sample data showed that the data is collected at 15 points once each hour-  the minutes are meaningless.  (and the timer relatively inacurate)
From that we could infer "something" about the desired user's story.  It might not be how I'ld do it but the second loop was not really needed as every bit of data in it was available in the first loop.
(3,907 Views)
I agree that it looks simple at first glance, but there could be many scenarios where the code could fail unless we make many assumptions about the input data. For example, if the date (or just AM vs PM) would change between rows, we would get quite a bit of ambiguity and malfunction. The code in the current form is not universal or safe because significant amounts of information is discarded.
In the most general case, the entire first column would need to be parsed as timestamp datatype.
If only the hours matter, a simple numeric diagram constant would suffice. Having a string formatted with minutes that are later ignored just adds to the confusion and hampers code readability.
(3,897 Views)
