Combination Lock using Labview
You'll have to explain what is the purpose of the array of booleans.  How does it have anything to do with a combination lock?
Message 11 of 15
(2,070 Views)
I need to use key or array to input the password
Message 12 of 15
(2,067 Views)
So you have to select one element in the array? Not that it makes much sense, but you should then OR it with the result from the three numerics.
I don't get the use of the ptbypt function. It would be simpler to have an event structure with a 'submit' button and in that event, check to see if the combination or array selection is correct.
Maybe you want one 'Correct' button and another 'Incorrect' button that you can flash. Your statement about flashing the single button and your existing control would make it just turn from either Green to Red or Red to Green.
Message 13 of 15
(2,059 Views)
Use 1 array to input
or use 3 keys to input
how to do?
can show me by vi? thanks.
Message 14 of 15
(2,053 Views)
Just go to the Boolean palette and use the OR function.
Message 15 of 15
(2,051 Views)
