Showing results forĀ
Search instead forĀ
Did you mean:Ā
Code for vending machine
Sir,
     I would like know the code for a vending machine which has x no of items and accepts any change and at the same time returns the excess change back to the customer.
           Thanking sir.
Message 1 of 21
(14,546 Views)
Accepted by topic author vendingmachine
State Machine.
Are you looking for somebody to just do this for you?  Or are you just stuck somewhere?  What have you tried?
Message 2 of 21
(14,540 Views)
if code is readily available i will go through it and try it
@crossrulz wrote:
State Machine.
Message 3 of 21
(14,535 Views)
i tried a vending machine which does not give change and acpets only the exact chnge so i would like to modify it if someone guides me
Message 4 of 21
(14,532 Views)
It doesn't seem like your problem is really solved.  So you might want to unmark my earlier post as the solution and give me a Kudos instead.
Care to share your code?  Tell us where you are stuck.
Message 5 of 21
(14,523 Views)
Are you doing this as practice for the CLD? If so you may want to spend time figuring it out on your own since there will not be anyone who can assist on the exam itself.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 6 of 21
(14,518 Views)
could kindly assist me with the code
Message 7 of 21
(14,508 Views)
no am not preparing for cld am at the basic level trying to learn labview
Message 8 of 21
(14,506 Views)
You need to show us some code so we know where you are at.
Message 9 of 21
(14,494 Views)
If you understand the existing code, it should be trivial to make these changes. Do you understand the code you currently have?
If you show us the original code, maybe we can give you some pointers.
Message 10 of 21
(14,494 Views)
