Question about Sound file to sound output
Hi there,
In the example "Sound File to Sound Output", the while loop is continuously reading and writing data to sound output device, but why it only plays the .wav file for one time?
How can I make the vi plays the sound file with each iteration?
Thank you!
(2,947 Views)
You can do something like the attached VI.wav output.PNG[Edit]: Sorry i didnt test this, but should work, you will also need to change the position mode on the sound file read vi to absolute.
Hope that helps.
-Matt
(2,936 Views)
