Cluster performance: "single unbundle" vs "multiple unbundle"
It's a surprisingly complicated question.
Are any of these VIs inlined?
When the LV compiler tries to ascertain whether a value can be read in-place or whether it needs to make a copy, there are a LOT of things which can influence that decision.
One which has gotten me in the pas:, compiled code complexity. If you have a lot of inlined VIs, the VI metric "Code complexity" is lying to you. The complexity of the code during compilation vs the complexity when looking at it in the IDE will differ significantly. And when the complexity (during compilation) gets too high, LV starts ignoring certain types of optimisation. So there's that factor to contend with. It's annoying because code which runs fine for years can suddenly become a performance bottleneck due to seemingly unrelated changes around the sub-VI. I had a case in the past where I was using IPEs, and was told my NI that this is actually not neccessary, and that using an IPE where the compiler can already know that it's in-place is actually costing me time. And since performance was paramount, I deleted the IPEs. Performance tanked (I'm talking 100x slower). I had run into precisely the situation I mentioned above. I had to re-introduce all of the IPEs. Usage of an IPE is not dependent on the compiled code complexity.
Message 11 of 16
(2,428 Views)
@billko wrote:
Edit: Well of course it was the last thing I tried, because it worked, but you know what I mean.  😄
Similarly, your car keys are always in the last place you'd look. 🙂
Message 12 of 16
(2,419 Views)
A little esoteric knowledge since both Mark and Bill are correct half the time.
Do multiple Unbundles force LabVIEW to copy the cluster data at each wire branch or can the compiler optimize and reuse the cluster data copy?
The answer may be.  If the cluster wire is brownish the data is contiguous in memory and the compiler might feel safe enough to operate on the same buffer otherwise, the cluster wire is not brownish (pinkish or greenish) and the data may be non-contiguous in memory and only copying the whole cluster data is safe.
To be honest, I disagree that branching the cluster to multiple unbundle nodes is cleaner than bending a few element output wires if you properly label your wires!
And if you still don't like that, make the cluster a class and use property nodes.  Or treat it as such in an action engine with get and set <element> actions wrapped with the "Nirvana" AE API vis.  Either of those choices force LabVIEW to share the Cluster data buffer in either the Class or on the SR/FBN of the AE Core.
"Should be" isn't "Is" -Jay
Message 13 of 16
(2,400 Views)
That's very interesting!  At any rate, I've moved away from this because, if you have to split up your unbundles like that, your VI is probably too complicated and needs to be broken up into subVIs.
Bill
CLD
(Mid-Level minion.)
Message 14 of 16
(2,374 Views)
Since I did mention Nirvana...... you should get some Idea from this incomplete lvlib
Message 15 of 16
(2,352 Views)
Yeah, code complexity is a bit more complicated when using inlined subVIs, but a bit for the background on why this matters: NI LabVIEW Compiler: Under the Hood - NI
If you take a look in this article, you will find that the compiler does a lot of optimizations, but it also has a clue in why the IPE helps improving the execution performance, and that is optimization passes.
The compiler has a setting that tell it how many passes it should perform for each VI. But if we imagine the use-case where we have a lot of nested VIs that are inlined, then the compiler will optimize the subVIs quite well. On the other hand the caller VI will get to a point of complexity where the compiler reaches the limit for the number of optimization passes before the code is optimized. There is a help page that explains when LabVIEW considers these limitations to be enforced: Application:Compiler Threshold - NI.
Furthermore, there is an article that provides steps to be taken to have more optimization happening inside the compiled code, at the expense of the compilation speed: Optimizing Execution Speed for Built Applications - NI.
But the overall best optimization is to write the code with the available function, operators and subVIs to the point where it is still maintainable (human readable, clean code) but represents the low level intents of the developer. Therefore using the IPE, placing only one unbundle on the BD, etc. shall be the way to go if that is what the developer expects.
There was a very good training material on the topic back while I was still working at NI, but I cannot see the performance related training as an available course anymore.
Message 16 of 16
(981 Views)
