Clear digital channels after loop
I'm pulsing 6 LEDs with Labview and the DAQ USB-6351, but I have an issue when the program stops.
I've attached the VI.
The problem appears depending on when the user stops the VI, the LED remains turned on.
I tried to solving this problem by writing false to all the channels, but this gives me a warning every time, and it doesn't solve the problem.
Any solutions?
Message 1 of 10
(3,999 Views)
What warning/error are you getting?  Why are you trying to read from digital outputs?
Message 2 of 10
(3,997 Views)
The readings from the digital channels are just to know which state the LEDs are in.
The warning im getting is: warning.PNG
Message 3 of 10
(3,985 Views)
Stop the task before writing your all FALSE.
Message 4 of 10
(3,970 Views)
You mean like this? I still get the same warning.
Message 5 of 10
(3,918 Views)
Almost.  Why would you restart your outputs right after stopping it?  That's just silly.  All you need is to remove that DAQmx Start that is done right after the DAQmx Stop Task.
Message 6 of 10
(3,901 Views)
Thanks for bearing with me..
When i remove the Start DAQmx, I just get another error:
Message 7 of 10
(3,877 Views)
Do the final Write (of all False) before you stop the Task (but after you exit the While loop).  The Task needs to be running fin order for I/O to take place.
Message 8 of 10
(3,861 Views)
Bob, if I remove the stop DAQmx I'm back to where I started. 🙂
Message 9 of 10
(3,838 Views)
Any hints?
Message 10 of 10
(3,784 Views)
