Check Array have only Identical Elements
Hello Vinal_G
Good job.
With Regards
Miraz
Kudos is better option to thank somebody on this forum
Message 11 of 13
(1,737 Views)
@SELVAN.skp wrote:
Hi Miraz,
To be clear from my side,If an array have 5 elements and all the 5 elements should be identical to themselves this is what i need to check.
What is the need to checkthis?! Smiley Indifferent  AFAIK, every element in an array WILL BE identical to itself. 🙂
- Partha ( CLD until Oct 2027 🙂 )
Message 12 of 13
(1,719 Views)
Parthabe,
I think auther wants to check that array has unique elements in it, that is tested using Vinal_G's logic.
I myself got confused after reading the title of the post.Smiley Wink
With Regards
Miraz
Message 13 of 13
(1,693 Views)
