Changing a .net constructor node with VI Scripting?
I'm trying to make a tool to generate wrappers around a specific .NET dll.
I created the node, then tried writing the property Constructor Node Class Name. I got error 1113, "LabVIEW: (Hex 0x459) Internal Error. The external object class was not found."
So, I manually made a node then read that property- aha, I need to add ".NET:" to the beginning of the method name; all well and good.
So, now I can write the property with that name and it works... until I go to write a different name.
Long story short, I seem to be able to write a type to a Constructor Node if I've manually set that node to that type before.
In other words, say my .NET assembly has methods A/B/C/D/E. If I manually set my constructor node to Method A, then B, then C, VI scripting lets me change it to A, B, and C, but not D or E. If I manually configure it to method D, now I can change it to A, B, C, and D, but still not E, until I manually configure it to E- then I can do whatever.
Any tips on getting this to work? I'm using "Assembly.LoadFrom" then "Assembly.GetTypes" to get a list of all Types. I thought this would pull the whole assembly into memory but it appears I'm not understanding something.
(2,385 Views)
Well, you're ahead of me.  I can't even create a property node for a contructor.
(2,311 Views)
Accepted by BertMcMahan
Hi Bert,
What about using private VI Server Application method ".NET > Load Assembly to ObjMgr" prior to scripting the constructor node?
See https://forums.ni.com/t5/LabVIEW/Scripting-a-NET-Constructor-Node-in-LabVIEW/m-p/4154118#M1198663
However, I haven't found a way to select a specific constructor implementation.
Raphaël.
(2,289 Views)
I "cheated" and just used a VI with one on there already as a template (not a .vit or anything).
@raphschru wrote:
Hi Bert,
Raphaël.
That did it, thanks a ton! I don't have the "which specific constructor do you want" issue so I can't comment there, but after calling the private VI you mentioned I can now set my constructor node to whichever specific constructor I need. Thanks for the tip!
(2,250 Views)
Creating the constructor node is easily done:
(2,200 Views)
Here it is wrapped up in a callable VI.
(2,180 Views)
