Changing File Version of built installer
Does anyone know how to change the file version and product version in the attached image. I need the file version to be 0.0.0.6 and product version to be I1. Thanks!
(1,398 Views)
Hi malanskas,
check the settings in the AppBuilder when creating an executable!
(1,340 Views)
The picture refers to the installer program setup.exe. You can't change its version, in any case it doesn't make sense to do this, since it's the same whatever the version of your application.There are separate Version infos for the built executable and the built installer, but the installer version is only included in some companion files (for sure in setup.ini and nidist.id).
Paolo
(1,332 Views)
The right way to make this change is to make a new build of the application, and installer.  But another route that I don't recommend, is to use something like a resource editor.  Years ago I used Resource Hacker to accomplish tasks like this.
(1,294 Views)
