Change properties of a cluster element withing an array of clusters
Hell Yamaeda, Oligarlicky, Jeff·Þ·Bohrer and altenbach.
Thanks for this last solution, while it is not the best option,
will require some refactoring to store the 'Conformité' message
outside the cluster array to replace it with a picture, it is still
the best and less work incentive alternative.
I will considerate this approach and develop a version from
it and will let you know if the result is satisfying enough for
my colleague.
David Koch
Message 11 of 35
(2,876 Views)
Accepted by Kochise
I took a little moment to hack your solution
into my program, and here's what I get :
It's still rather strange that Excel, a simple spreadsheet
program, can change individual cell's color, but not a
powerful dataflow-based, graphical, programming
language such like Labview.
Anyway, that done the trick, solution adopted !
Kudos raining !
David Koch
Message 12 of 35
(2,784 Views)
So I'm guessing you know this, but in that VI you aren't dealing with a table, like you are in Excel.  If you have a LabVIEW table you can change the cell color of each cell without affecting the other cells.  But what you have there is an array.  And an array contains elements, and the only thing allowed to change between the elements is the value.   There are several ways to get the behavior you want visually, but arrays cannot do it.
Message 13 of 35
(2,766 Views)
Of course I know, but I'm still rather disappointed.
The array of elements 'should' ('could' ?) have
duplicated not only the data elements but also
the attributes elements to allow playing with
each of them individually, or allow bulk change
(like 'select column, change color')
What other choice have I had to chose between ?
David Koch
Message 14 of 35
(2,754 Views)
I'm having a hard time finding the link now, but there was a demo where what was displayed to the user was a cluster not an array.  The cluster can have individual elements have different attributes of couse.  Then there was a vertical scrollbar that when it would change would change the data in the cluster, giving it the appearance of an array, but actually being a cluster.
It can be a lot of work, and I wanted to make some tools to make this easier, but depending on how particular you are about your UI you could give it a try.
Also if you are okay with the background color changing and the font staying the same color, you could hide a colorbox behind the string indicator, and set it to be transparent.  Then the value of this colorbox is the background of the string.  Sorta like this.
https://forums.ni.com/t5/LabVIEW/Coloring-elements-in-array-of-clusters/td-p/1992041
Message 15 of 35
(2,744 Views)
I'm a little late to the party here but nathand put together an excellent example a while back that demonstrates the table idea that hoovah mentioned. Its got a slick interface, and like hoovah pointed out you can modify the color of the text since its a table control not an array.
https://forums.ni.com/t5/Example-Code/Click-to-Edit-Table-Using-an-Array-of-Clusters/ta-p/3508160
Message 16 of 35
(2,721 Views)
Thanks, but that looks like a lot of effort to tweak UI
appearance while an array of cluster should have
not linked attributes together.
I mean, you can loop through all the data and set them
to the same if you want. Or have data set individualy.
You might have been able to do the same with the
attributes of each cluster's element, loop through
all of them to set the same text font/color, or set it
on an individual fashion.
Perhaps using the same loop, with something
looking a lot like cluster bundling.
But not, instead all the attributes of a single cluster
are linked together, who knows why.
While Labview was supposed to help the 'technician'
to create color rich user interface, it just shows how
much it is far from reality, cumbersome, needlessly
overcomplicated to perform somewhat common
data presentation.
Am I a dreamer or just a grumpy old man expecting
something out of his software registration from a
well established software company ?
I'm fed up trying to tweak the language into something
it was finally neither engineered nor updated for.
Just look at my useless fighting with variant, supposed
to be the cornerstone of the G programming language,
the peak of evolution. You only get unsupported and
undocumented VI to play with instead (hidden VIs in
the VariantDataType folder)
My Labview and Teststand experience is far from
being satisfactory, I don't think any additional and
expensive NI courses would solve any of my issues
with them, as the problems are deeply rooted into
the products' functionality. Or lack thereof.
David Koch
Message 17 of 35
(2,706 Views)
Though I'm with you on lamenting the lack of a suitable UI element in LabVIEW that easily does what you want, there is good reason why the current array control uses a single set of attributes.  It is much more overhead (performance and memory usage) to have independant attributes for each array element.
Message 18 of 35
(2,684 Views)
BTW, have you thought about just using a Cluster instead of an Array?   You can easily get an array of references to the cluster elements and thus update all their attributes individually.  The Cluster will be of fixed size, but you can hide (or disable-grey) unused subclusters.
Message 19 of 35
(2,678 Views)
That argument, again.
We're not dealing with embedded development in
constrained environment. We're dealing about desktop
application with dataflow based graphic programming
language.
The operating system being mostly Windows based,
you already have to fit a handful stick of RAM just to
get the machine up and running.
Don't tell me that duplicating the String's attributes
(font, size, color) would be such a memory overhead.
I'd like we remain a bit professional and use sensed
arguments to defend our pitch.
David Koch
Message 20 of 35
(2,675 Views)
