creating VI from text file
Is it possible to import a text file in Labview with logic "NOT", "AND" and "OR" functions, and let Labview draw the shematic of the logic on the front panel?
(2,955 Views)
You want the boolean logic schematic?  I suppose it is possible if you get really fancy with the picture control.
(2,953 Views)
Almost anything is possible.  Take a look at what Darin.K did here - https://decibel.ni.com/content/docs/DOC-13859  That'll take the text and make a VI.  The logic will be on the block diagram, however.  You might be able to do something with that.  How good are you at scripting LabVIEW?  You can certainly roll your own.
Jim
(2,942 Views)
Heck, Just script the BD of the logic and toss it in a sub-panel on the FP.Smiley Wink
"Should be" isn't "Is" -Jay
(2,899 Views)
