Change colour of selected tab in a tab control
I am looking to change the colour of the selected tab in a tab control.
For example I have a Tab Control with 3 tabs (P1, P2, P3). What I want is when P2 is selected, it is highlighted say by making the whole tab Red but P1 and P3 are say grey. Hence when say, P1 is then selected,it is Red and P2 + P3 are Grey.
Is there a way to do this - I have enabled Multiple colours in my Tab Control
Help would be appreciated
Cheers
Marsh
Message 1 of 14
(10,665 Views)
Hi Marsh,
you can set colors by either right-click+Properties or by using property nodes. Just read the help for the properties of the tab control!
Message 2 of 14
(10,654 Views)
The VI here should be enought to get you there
Tim Elsey
Certified LabVIEW Architect
Message 3 of 14
(10,626 Views)
Here is my version allthough the one suggested is much better and efficient.
Message 4 of 14
(10,607 Views)
This is a better option.  The VI is attached.
Tim Elsey
Message 5 of 14
(10,596 Views)
Can you save that as a Labview 8.2 file please - I'm not as up to date as you!! Thanks and Sorry!
Message 6 of 14
(10,589 Views)
Accepted by topic author Magical Marshmallow
Tim Elsey
Message 7 of 14
(10,579 Views)
Howiya
I'm not sure if its as a result of using the VI you sent me earlier or not!
I have graphs on the Tabs on my Tab Control, these did update in real time however they now only update when you click back to the tab in question.
Is there a reason for this and how do I remedy this problem
Cheers
Marsh
Message 8 of 14
(10,554 Views)
Magical Marshmallow wrote:
Howiya
Cheers
Marsh
It is expected behaviour that non-vislable graphs do not update if not visable. I can only guess that now that you have changed to background color it is taking longer to update them and now you can see the update happening.
Ben
Message 9 of 14
(10,551 Views)
Hi
Would it be possible to do something similar using images for the tabs, and change the image for the active tab?
Simon
LabVIEW 8.6 / 2009 / 2010
Vision Development Module 8.6 / 2009 / 2010
VBAI 3.6 / 2010
Message 10 of 14
(10,492 Views)
