Change color of indicator
I am struggling to change the indicator color based on user button selection. Can someone help me? I need to save the color as well but don't know how to connect all.
(6,148 Views)
Use the property Named Colors, and feed the values based on the selection of color you Need.
You can use color box constant to feed the color based on your switch selection
(6,141 Views)
That's what I did. But I am not getting it right.
(6,138 Views)
Hope this helps you!
(6,131 Views)
I understand how that works. I just want to connect what I have already and know how to.
(6,120 Views)
Accepted by topic author BArtzon
Then use "bundle" and "build array":
Regards, Jens
Kudos are welcome...
(6,091 Views)
Perfect. Do you know anything about the save boolean? How would you save each image when you press "save led image"?
(6,086 Views)
