Change color of indicator
I am struggling to change the indicator color based on user button selection. Can someone help me? I need to save the color as well but don't know how to connect all.
(6,135 Views)
Use the property Named Colors, and feed the values based on the selection of color you Need.
You can use color box constant to feed the color based on your switch selection
(6,128 Views)
That's what I did. But I am not getting it right.
(6,125 Views)
Hope this helps you!
(6,118 Views)
I understand how that works. I just want to connect what I have already and know how to.
(6,107 Views)
Accepted by BArtzon
Then use "bundle" and "build array":
Regards, Jens
Kudos are welcome...
(6,078 Views)
Perfect. Do you know anything about the save boolean? How would you save each image when you press "save led image"?
(6,073 Views)
