Change VI from function palette
Hi all,
During programming I called "Write Delimited Spreadsheet VI" from the function palette on Labview2015.
For some reason I have edited the VI (called from function palette) to fit my use.
Now the problem is that after editing the VI, it will call the edited VI but not the default one when I click "Write Delimited Spreadsheet VI" icon on the function palette.
Is there anyway to change it back to the default one ("Write Delimited Spreadsheet VI" without editing)?
regards
(2,907 Views)
Accepted by topic author IanYuan
Hi hsyuan,
try to repair your LabVIEW installation. Or deinstall LabVIEW completely and install again…
Lesson learned: NEVER EVER edit functions provided by NI. If you intend to create your own version of such a function you NEED TO create a fresh copy of that function!
(2,895 Views)
Hi GerdW,
That's a bad news :'( Thanks a lot for the information!
(2,825 Views)
