Challenge of the Day: No palette!
Cite one FP object, which, when right-clicked, offers no palette to pick up a related function or object.
EDIT: I meant Block Diagram (BD) objects, not Front Panel objects (FP), my bad.
Message 1 of 22
(4,488 Views)
Native palette? If not, OpenG Front Panel buttons won't cite back to their palette, but that could just be an add-on thing.
Cheers
Message 2 of 22
(4,483 Views)
All of the .Net and ActiveX palette items.
Cheers
Message 3 of 22
(4,478 Views)
We are talking BD objects, my bad.
I am talking about this behavior:
Message 4 of 22
(4,458 Views)
Oh, that's a tough one...
I'm trying to figure out why your right-click menu doesn't have a breakpoint option there too. Maybe that's a clue.
Cheers
Message 5 of 22
(4,429 Views)
XNode is the easy answer.  I can make an XNode that using the reference to the right click menu just deletes all items.  Are you saying there is one shipped with LabVIEW that does this?
EDIT:  Oh that feature I've always found as half broken.  Some times it works some times it doesn't.  Especially for userlib stuff.
Message 6 of 22
(4,417 Views)
Stacked sequence structure doesnt... (in 2014) 🙂
... meaning my guess is that any old functions that are supported for backward compatability but not available in palettes would have this behavior.
Message 7 of 22
(4,409 Views)
But stacked sequence isn't on the palette in 2014 right?
EDIT:  Oh is the answer a VI that merges a VI?  Then the merged VI would be on the palette but not the function it drops.
Message 8 of 22
(4,401 Views)
You can right click a regular seq structure and convert.
Cheers
Message 9 of 22
(4,398 Views)
Yes you can make it but isn't on the palette.  If that isn't a requirement then I'd say there are tons of stuff, practially any VI, in the vi.lib would qualify.
Message 10 of 22
(4,378 Views)
