01-02-2013 06:51 AM
Hello everyone. I need a case structure, which is controlled by a boolean button. I need to use my timeout by switching my button to "true", but it fails:
01-02-2013 07:03 AM
In the false you can wire -1, can you explain why you are trying to do like this and what you want to achieve finally?
01-02-2013 07:16 AM
Hi P@Anand
My PC is serial port communicated with a scale. The program makes auto measurement every "x" seconds, when i define the timeout to a number "x". But i don't want to use auto measuring sometimes, and will measure by self clicking on the measurement button. So therefore i want at boolean ON/OFF to the timeout value.
01-02-2013 07:23 AM
But it works now.
Thanks a lot !
01-02-2013 07:23 AM
You can use an event case to toggle using the timeout control. Check the attached code
01-02-2013 07:24 AM - edited 01-02-2013 07:25 AM
In these situations, I must prefer using the Select function. Makes things a lot easier to read.
01-02-2013 07:25 AM
We are on Page ![]()
