キャンセル
次の結果を表示
次の代わりに検索
もしかして:
Is it possible to generate a waveform without using DAQ?
hi, i want to ask if it is possible because i am only trying to run a demo VI without the hardware. Thanks!
0 件の賞賛
メッセージ1/4
2,753件の閲覧回数
Hi txrxmo,
yes, that's possible!
スポイラ
In case you want to know how: There's a whole functions palette with functions to generate waveforms...
0 件の賞賛
メッセージ2/4
2,747件の閲覧回数
If you want to simulate hardware, check this out: NI-DAQmx Simulated Devices.
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
メッセージ3/4
2,733件の閲覧回数
Go to the Signal Processing->Waveform Generation palette.
メッセージ4/4
2,726件の閲覧回数
