cancelar
Mostrando resultados para
Pesquisar então
Você quer dizer:
Case structure always has a missing enum value
Resolvido!
Ir para a solução
I have been unable to get all enum values to appear in a case structure.
This is the enum:
This is a test setup:
The full enum is visible for Obtain Queue and Enqueue Element.
The value for Enqueue Element was created using Create Constant.
However, the case structure only displays the first 2 of the 3 enum values.
After creating this test setup, the nonzero enum names were changed to "A" and "B".
Enum names updated everywhere, including the case structure, but the case structure still does not include "B".
The enum is strict:
What can I try or what have I missed?
Mensagem 1 de 7
995Exibições
Solução
Aceita por spideyK
Add one more case and type "B" into the selection...
Or right-click the case structure and select "create case for each item"!
Mensagem 2 de 7
988Exibições
The test structure was added to the main VI in a project where the issue made its appearance in a sub VI of that main VI.
This is to say the example was not created in a new VI.
Mensagem 3 de 7
980Exibições
When dealing with Enums and Case Statements, here's what you should do to prevent "missing enum value" errors:
  1. Wire the Enum to the (initially empty) Case Statement.
  2. Right-click the Selector at the top and choose "Add Case for Every Value.  In your example, it will populate with the three Cases "A", "B", and "Null", Default (the last case has two entries, "Null" and Default).
  3. My advice is to remove the Default part of the last entry.  This way, if you then later add a "C" case to your Enum, the Case structure will "break" and force you to think "What do I want to do if it is C" (rather than accept the "Null" case, which it certainly isn't).
  4. The other thing you can do is to change the Sort order of the Cases between "Alphabetic" and "Enum Order".
Mensagem 4 de 7
897Exibições
Thank you Gerd for clearing up my brain fart!
Mensagem 5 de 7
891Exibições
Thank you Bob for your suggestion. If the default is removed, the null entry can also be removed since it was added as a do nothing value since there is no default behavior. Live and learn.
Mensagem 6 de 7
885Exibições
You can actually right-click anywhere on the case frame to do that.  (I had actually thought that you had to right-click anywhere other than the Selector, until I just tried it).
Mensagem 7 de 7
833Exibições
