Case Structures
I have developed a case structure but I want to be able to reset it to its default state instantaneously. Each structure contains a while loop so I must end the loop and then use a select comparison to decide which state to go to. That part works, however it only works if I have a stop button in every while loop. Is there a way to compine multiple stop buttons into just one on the front panel while still existing in multiple states in the block diagram?
(3,039 Views)
I'd use local variable (right click on the button in block diagram -> create -> local variable).
edit:
alternatively you could just have the stop button outside the case structure and wire it's output to all the while loops (i'm assuming there is a larger while loop outside the case structure)
(3,031 Views)
Accepted by BrassBandit
It would help if you attached a VI.  But from what you described, you either have things backwards or more complicated than they should be.
I would not put while loops inside of case structures.  Since you used the term "state", I assume you have a state machine.  The best structure of a state machine is a case structure inside of a while loop.  No additional while loops inside of cases.  If you need to stay in a state, then you have your state machine to decide to go back to the same state or move onto another state.
(3,008 Views)
Unfortunately, I cannot show the VI but I agree that it is more complicated than it should be. I will attempt rebuilding the state machine. The issue i was having with local and global variables is that it would not read the value until the loop that I wanted to stop was conplete.
(2,984 Views)
Help -> Find examples -> State machine fundamentals should give you some good tips. 🙂
Qestit Systems
Certified-LabVIEW-Developer
(2,957 Views)
I agree with RavensFan. Make your state machine the loop and just repeat the state if needed. There is no need for local or global variables.
(2,907 Views)
