Labview for SPS
in our company we use Labview to define the operation of plants for different customers. Now a customer wants to operate a plant which should be build from our company with a Siemens SPS. The plants of the customers of our company are usally very similar.
Is it possible to use the defined Labview project in an easy way for operation with a Siemens SPS?
We saw there is a possibility to use C/C++ with a Siemens SPS. Would it be a solution to migrate the Labview project to C/C++? If yes how?
CB1000
(3,013 Views)
I have not heard of a Siemens SPS before.
I can tell you, there really is no way you'd want to try to "migrate" LabVIEW to C/C++.  Though it is possible to build LabVIEW VI's into .dll's that can be called by other languages.
Is SPS a software program by Siemens?  What does it do?  What interface does it have that you can communicate with it?  There are a number of ways LabVIEW can talk to other software via TCP/IP or other communication protocols.
(3,010 Views)
the English term for SPS is PLC, and Siemens sells a lot of them...
You cannot convert your LabVIEW project into a PLC program (to put it in simple words). There are toolkits available to communicate with a Siemens PLC from LabVIEW, but this probably isn't what you want to do?
(2,966 Views)
Well that explains a lot.  I searched for "Siemens SPS" and just found a conference.
Yeah, PLCs are all there own thing, using Ladder Logic.  But I have communicated with PLCs using EthernetIP (NI has a good toolkit for this) and simple DIO (usually "Part Good" and/or "Part Bad" lines).
(2,929 Views)
PLC's I know.  "SPS"  I've never heard that abbreviation before.
I'm using Modbus TCP/IP to communicate with PLC's.  And they are using ladder logic for their internal programming.
(2,918 Views)
SPS is German for "Speicher-Programmierbare Steuerung" (here)...
(2,910 Views)
