Case Structure
In the attached VI, I have taken 'String element' from an array and fed it to case selector. But, case selector isn't working. (executing only the default case)
Please explain what's going wrong.
Thanks.
Message 1 of 13
(6,310 Views)
Accepted by Ganny
See those unconnected wires that you use on the output of most events? Since it is not connected it will have the "default value" of the underlying datatype (i.e. on string an empty string).
If you don't understand this, see for yourself what is going on and watch your block diagram in highlight execution mode.
Regards, Jens
Kudos are welcome...
Message 2 of 13
(6,300 Views)
Accepted by Ganny
Your problem is the unwired output tunnels from your Event Structure.  I highly recommend you turn off the Use Default If Unwired option for all of your output tunnels.  You just wire the values straight through if you are not updating the values.
Message 3 of 13
(6,299 Views)
Accepted by Ganny
@crossrulz wrote:
...  I highly recommend you turn off the Use Default If Unwired option for all of your output tunnels. ...
Excellent advice that I recommend myself. The option to use the default if not wired may reduce frustration with novice developers that may not be able to figure why the VI is broken, but they can and will introduce a challenge when trying to figure out why applications are not operating correctly, as is the case in this thread.
Spoiler
The first time I encountered the reprecussions of the use default if not wired was an application that worked great in every regard save one out of the blue situation where when the phase of the moon was wrong and the cat was swung the wrong way (yes a cat was harmed in the trouble shooting of that code I have to admit) an unwanted result occurred. it was a file reference that was not wired through a Event Structure. Took a while to figure what phase of the moon was required to be able to reproduce the problem.
Once burned, twice weary.
Ben
Message 4 of 13
(6,281 Views)
Just to complete the thought:  They only time I use the Use Default If Unwired on a regular basis is for the stop condition.  This works because only 1 case should be stopping the loop and the default for a Boolean is FALSE.  It is just a little convenient to only have to wire up the constant in 1 case.  There are exceptions, but very rare.
Message 5 of 13
(6,256 Views)
I use it often with Booleans but NOT as the default. It makes ME think what I want to pass along. When used as the default it could set me up for a problem that may not show up with testing every variation.
Ben
Message 6 of 13
(6,253 Views)
Thanks Ben and CrossRulz. Now I learnt what was happening. I got it working.
Cheers.
Message 7 of 13
(6,245 Views)
Just to put a bow on it...
There's a somewhat new-ish feature (at least my *awareness* of it is new-ish) that's sometimes really helpful.  You can right click a right-hand-side tunnel and assigne a "linked input tunnel".  There's even an option to auto-wire the unwired cases.
This pays off nicely when you have shift registers on your enclosing loop, and most of the cases just pass the value straight through.
-Kevin P
Message 8 of 13
(6,221 Views)
Hey there,
While I'm trying to add some more features to the calculator like adding another display that shows the operands. I'm partially successful. For instance, if I want to add 3 and 4, I want to display "3+4". I could manage displaying "3+" by concatenating strings but couldn't get the '4'.
Any suggestion on how I can accomplish it?
Message 9 of 13
(6,203 Views)
Linked Tunnels was one of my favorite features when it came out back in LabVIEW 8.6.  I consider them a must for state machines.
Message 10 of 13
(6,202 Views)
