Case Structure and Numeric Indicator
May I know how I going to display my value 1 by 1 ? It display too fast. I want to see the value change 1 by 1.. for example 1 to 2 then to 3 and so on. Attach is my vi, correct me if got mistake.
Message 1 of 14
(7,759 Views)
First of all you must know functionality of while loop and case structure and then utilize them in the code.
You can find 'Context help' for that Ctrl+H in LabVIEW.
Also if I am not wrong you can use a while loop and a wait(ms) function to delay the counter.
Message 2 of 14
(7,735 Views)
I don't have labview pc now, but according to your description "It display too fast" use delay and you can slow down the display speed.
uday
Message 3 of 14
(7,733 Views)
You will also need to put the indicator inside the loop in one case and a local variable (of the indicator) in the other or you will only see the change at the end of the execution.
Message 4 of 14
(7,719 Views)
Would you mind to show me how does it look like? I still can't get it.
Message 5 of 14
(7,686 Views)
Message 6 of 14
(7,686 Views)
That's not how this Forum works -- you show us what you are doing (by attaching the VI you are trying to write, along with a description of what you want it do to) and we will suggest "fixes" that will (with luck) fix it.
Please attach your VI (not a picture of the Block Diagram, but the VI itself).
Message 7 of 14
(7,674 Views)
You need to learn what is case structure and how to use it : https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/structures/case-structure.html
-To slow down the execution speed you need to understand wait:https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/functions/wait-ms.html
You should learn LabVIEW basics from here : https://learn.ni.com/learn/article/labview-tutorial
uday
Message 8 of 14
(7,662 Views)
This one is my VI. Which I implement on my FPGA target VI. Am did any mistake on my VI ? I still dunno which one will cause the problem since error is not occur. Thank you.
Message 9 of 14
(7,653 Views)
Your counter indicator will not update until the loop has finished executing and then it will display either 0 (counting down) or 255 counting up.  If you want to see the indicator labled 'counter' counting up (or down) then the indicator (or a local variable attached to the indicator) MUST be inside the loop.
Ken
Message 10 of 14
(7,647 Views)
