Case Structure and Numeric Indicator
@Ken_Naylor wrote:
Your counter indicator will not update until the loop has finished executing and then it will display either 0 (counting down) or 255 counting up.  If you want to see the indicator labled 'counter' counting up (or down) then the indicator (or a local variable attached to the indicator) MUST be inside the loop.
Ken
Even I put the indicator inside the SCTL the counter value still not counting 1 by 1.
Message 11 of 14
(2,455 Views)
Accepted by topic author Ambrose1464
Message 12 of 14
(2,447 Views)
Or this which is close to your original (I think the solution from PalanivelT is better though)
Message 13 of 14
(2,441 Views)
Your inner loop has a fixed number of iterations, known before the loop starts, thus it needs to be a FOR loop.
Since the two cases are nearly identical, you don't need a case structure.
Here's one possibility:
Feel free to adjust the time delay (currently 200ms).
This is much less cluttered that some of the other suggestions with lots of duplicate code and even local variables. 😉
Message 14 of 14
(2,427 Views)
