Capturing an Image from a webcam in LabVIEW without Vision toolbox
Always fun with password protected VIs. Smiley Very Happy
So what do you want us to tell you about that VI?
Rolf Kalbermatter  My Blog
Message 11 of 20
(5,588 Views)
The password is "kengkeng".
Just wondering is it possible to get a still image with that VI
Message 12 of 20
(5,583 Views)
Found the thread and the password is actual kangkang. If you look at the program you will see that it uses a .NetPicture box. That object has a property Image and if you connect a method node to that Image refnum you can select a Save(String filename) method.
While I haven't tested it I think this is pretty much all that you would need for this.webcam.png
Message 13 of 20
(5,579 Views)
@PhysicsFTW wrote:
Hi Rolf,
Its part of a larger project that has to be done on labview.
What "Version" of LabVIEW do you have (Base, Full, Professional)?  Are you at a University that has LabVIEW through an Academic Site License?  If so, you should be licensed for the Vision Development Module (which includes code to create single Images in various formats, including PNG, and also videos in AVI format) and the Vision Acquision Software that can acquire images from both USB Webcams (most models) and also several Ethernet-based cameras.  The software is fairly easy to use (though the documentation is a bit "iffy") and is quite robust.
Message 14 of 20
(5,566 Views)
Hi rolfk
My labview skills are very basic im having trouble following your suggested method would you be able to describe a more detailed method to do what you suggested in getting labview to take a picture.
Message 15 of 20
(5,535 Views)
Accepted by PhysicsFTW
Well lets try to go step by step.
1) Place a button on the front panel and name it Save or something
2) Right-Click in the diagram on  the event structure and select Add Event Case
3) Search for your Save button and select it, and the event Value Change
4) Put the terminal for your Save button into that new case
5) Go on the Picture Control on the front panel, right click on it and select Create->Local Variable
6) Place that local variable in  your event case
7) Select a property node from the function palette and put it in the event structure and wire its refnum input to the local variable
😎 Select in the property node the Image property
9) Place a method node in the event structure and wire its refnum input to the Image property
10) Select in the method node the Save method.
11) Place a File Dialog Express VI on the diagram and als a Path to String node
12) Wire the path output from the File Dialog to the Path to String node and the string output to the filename parameter of the Save method
Voila!
Message 16 of 20
(5,513 Views)
and the final example is??? 🙂
Message 17 of 20
(5,247 Views)
I followed the steps but the result is that I get the error I reported in the attached picture.
Any suggestion ?
Message 18 of 20
(5,217 Views)
Hi
Attach the example that you build.
CPalka
Message 19 of 20
(5,208 Views)
We need to see VIs, not pictures of VIs, and certainly not pictures of Error Messages!
Message 20 of 20
(5,197 Views)
