Capture data from Arduino UNO
@BArtzon wrote:
No I am not.
Bytes at port was removed.
Everything works somewhat fine... but sometimes when I stop the program and run it again the values does not change when I move the IMU. Can you think of any reason?
Arduino IDE work fine like expected.
When you stop the LabVIEW program without closing the serial port properly, the resource can get locked and you won't be able to read data without restarting LabVIEW. Check if you are doing the cleanup after execution properly when exiting the program.
Message 11 of 15
(2,099 Views)
How would I do the clean up?
Message 12 of 15
(2,091 Views)
Are you closing the port VISA reference at the end of your program?
Posting your code would go a long ways here, otherwise we are just guessing.
=== Engineer Ambiguously ===
Message 13 of 15
(2,085 Views)
Yes. I am closing my the port at the end.
Message 14 of 15
(2,077 Views)
Why is it that sometimes when I run LabVIEW it gets stuck with some data and when I try to move the IMU, the data does not change. Is it because my computer is slow or something?
Message 15 of 15
(2,074 Views)
