Is it possible to create a vi with a customizable number of same input type?
Is it possible to create a vi with a customizable number of same input type like the "Compound Arithmetic" vi? I mean a vi which if I expand it on the vertical dimension automatically add same type of input ports.
Message 1 of 15
(4,099 Views)
You could do it through xnodes and VI scripting, however it wouldn't be trivial to implement, especially if you don't have experience with either.. Why do you want this functionality? If the inputs will be the same type, why not just make the input an array?
Message 2 of 15
(4,090 Views)
Practical Answer: You would be very much better off by just accepting an array input.
Technically Correct Answer: Yes but it is not supported and poorly documented
https://lavag.org/files/category/10-xnodes/
Message 3 of 15
(4,088 Views)
I know that an array could be a good solution but I don't know the number of the inputs a priori.
Message 4 of 15
(4,084 Views)
What is your vi going to be doing with the inputs?
Message 5 of 15
(4,076 Views)
You can either build the arrays programmatically or you can just expand the build array function to multiple inputs and wire the output to your function.
Message 6 of 15
(4,075 Views)
My inputs are clusters with the same organizzation of data.
Message 7 of 15
(4,070 Views)
Maybe this could be the quik solution. Can I do it with clusters as input?
Message 8 of 15
(4,067 Views)
Again, what are you planning on doing with those clusters in your vi? If you have 3 input clusters, what would the code do? What about 10?
Message 9 of 15
(4,066 Views)
In every input cluster I have a density spectrum, two number which define a band and a number which defines a threshold. In output I want a boolean signal which tell me if the threshold for every spectrum in his defined band is passed.
Message 10 of 15
(4,031 Views)
