Cannot work on cRIO in project
Hi guys,
I am trying to add a cRIO to my project (or work on an existing project with a cRIO in it). We just got the real-time license for this computer, but I cannot add or work on the cRIO. (Images below).
So far, I have tried re-installing the entire LabVIEW 2014 SP1 installation including device drivers and restarting the computer. Do I need the FPGA license as well? I believe the original application was developed in LV 2013 and the developer said he only used the Real-Time license. Thank you for any help.
(4,055 Views)
Accepted by topic author Gregory
What you show indicate that you do not have the driver installed. A screenshot of your MAX software tab can confirm this. When you install the RIO driver make sure that ADE support for your LabVIEW version is selected.
(4,038 Views)
Thank you Jacobson. I will pop the RIO device driver disc in. In the meantime, here is a screenshot from MAX:
(4,034 Views)
I did not see anything that specifically said ADE Support. When I tried installing the drivers this morning, I noticed that quite a few items could not install because a later version was found. I went into the NI software and removed everything related to real-time drivers that I could find. There was still quite a bit that could not be installed, but after this install, I can work with the cRIO in the project. Thank you for your help! Below is a picture where the first 2 are frames are what was selected to install, and the next 2 frames say what can and cannot be installed.
(3,996 Views)
