Cannot edit block diagram
The right-click menu doesn't seem fully populated...
Bill
CLD
(Mid-Level minion.)
Message 11 of 20
(1,695 Views)
@Tsotne wrote:
I've installed it this morning, it gave me 45 days free trial, I thought I could use it with that license.
Maybe "your thought" is wrong.  Go ahead and license it.  If you cannot (for some reason), call NI, figure out why not, go ahead and "jump through their hoops" and give them the information that they require to allow you to use LabVIEW "for free" (with some restrictions -- "if you can't stand the Restrictions, get out of the Community Edition" (a paraphrase of a well-known aphorism).
Message 12 of 20
(1,678 Views)
Thank you Mr. Ko!
That spun the magic 8-Ball.
@ the original poster.
~~~~Oh Magic 8-Ball,  "Did the poster close all running applications during installation & reboot after installation was complete?"~~~
The 8-Ball says: "It appears unlikely."
NOTES:
  • I've probably made more mistakes using LabVIEW than the number of choices you have made using LabVIEW (In the US Navy we said "He's flushed more seawater than you've seen.")
  • One of these days I'll figure out @mentions.
"Should be" isn't "Is" -Jay
Message 13 of 20
(1,665 Views)
That is NOT the Right-clilck menu, that is the new  "LEFT click followed by a Right-Click" menu.
To OP, try to make a little wire before doing a Right-click.
Message 14 of 20
(1,649 Views)
Yes that is left click and then right click menu, but these create options don't work, I'm trying to make them work.
Message 15 of 20
(1,642 Views)
Any custom shortcut menu plugins?
These probably stay in your install directory and\or in or user directory. So a repair or uninstall\install won't fix it.
I expect that a shortcut menu could mess up both the menu as what the menu items do.
I don't see how this could mess things up accidentally though. So if you have no idea what a shortcut menu plugin is, it's probably a red haring. Unless your host has been used by others before you...
They are here:
<user directory>\Documents\LabVIEW Data\PopupMenus
<labview.exe dir>\resource\plugins\PopupMenus
The first directory is shared by all LV versions.
The 2nd directory should have a bunch of llbs... You can temporarily delete them to see if one causes problems, but they are probably shipped by NI.
Message 16 of 20
(1,637 Views)
Accepted by Tsotne
And they don't work even if you make a wire before your Right click ?
What happens if you just use the Right-click ?
Message 17 of 20
(1,625 Views)
The R-click menu is new in 2023Q3, are you sure you have that version?
Qestit Systems
Certified-LabVIEW-Developer
Message 18 of 20
(1,614 Views)
The Getting Started window in the video shows that.
Message 19 of 20
(1,608 Views)
Create options worked from the full menu, I didn't know if it was there till you showed me. The small menu (left click, then right click menu) create options still do not work. I will check the directories of the menus and update this post if I make it working.
Message 20 of 20
(1,591 Views)
