Canalyzer OnInit event can't be accessed
I can access the com objects methods but I can't use the events (can't see them). Does anyone know why?
I must get access to  the OnInit event.
(4,536 Views)
Is this just a continuation of your earlier thread? It might be better to continue the discussion there, otherwise people have no idea what you're talking about. I certainly didn't by just looking at this thread.
(4,528 Views)
You should use the 'Register Event Callback' function on the ActiveX palette, you feed your com object into the 'Event' terminal, select the appropriate event (OnInit) and right click on the 'VI Ref' terminal and select, 'Create Callback VI'.
This will create a VI with the correct terminals, in this VI you should deal with the event. You could forward it into a user event.
Let us know how this goes.
Ton
My LabVIEW Ideas
(4,513 Views)
Accepted by magnuslilliehook
It works fine. Thanks for the help
(4,413 Views)
I have the same problem. How to create GetFunction in a OnInit event with TestStand ??
(3,906 Views)
I am trying to access CANalyzer with LabVIEW, start/stop a measurement and save a log based on the guide below.
https://cdn.vector.com/cms/content/know-how/_application-notes/AN-IMC-1-036_Using_LabView_via_CANape...
May I ask you to share your code for reference?
Thank you.
(290 Views)
