If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
01-02-2010 01:30 PM
I can access the com objects methods but I can't use the events (can't see them). Does anyone know why?
I must get access to the OnInit event.
01-02-2010 03:50 PM
01-03-2010
01:32 AM
- last edited on
11-06-2024
03:44 PM
by
Content Cleaner
You should use the 'Register Event Callback' function on the ActiveX palette, you feed your com object into the 'Event' terminal, select the appropriate event (OnInit) and right click on the 'VI Ref' terminal and select, 'Create Callback VI'.
This will create a VI with the correct terminals, in this VI you should deal with the event. You could forward it into a user event.
Let us know how this goes.
Ton
01-25-2010 06:23 AM
02-09-2012 07:03 AM
I have the same problem. How to create GetFunction in a OnInit event with TestStand ??
08-12-2025 06:40 AM
I am trying to access CANalyzer with LabVIEW, start/stop a measurement and save a log based on the guide below.
https://cdn.vector.com/cms/content/know-how/_application-notes/AN-IMC-1-036_Using_LabView_via_CANape...
May I ask you to share your code for reference?
Thank you.
