Can not intall Labview for Linux
My OS is SUSE enterprise desktop 10.0, the LabVIEW version is 8.0. When installing the version, a message appears as follows:
  * NI-KAL 1.1.0f0 for Linux/x86
******************************** ERROR ****************************************
* Kernel source in /lib/modules/2.6.16.60-0.21-smp/source does not appear to be
* configured for the 2.6.16.60-0.21-smp kernel.
* Configuration of kernel source is required to continue installation.        *
* Refer to the README file for the product you are installing for information *
* about configuring your kernel source.                                       *
Installer is aborted.
Please advise how to resolve the problem. Thanks.
David
(2,924 Views)
It seems that LV80 is not supported on SuSE10.0.
See the following link for more details:
http://digital.ni.com/public.nsf/websearch/35D2B5E483A001A18625716B005BE464?OpenDocument
帖子被pine在 12-16-2008 12:26 AM
时编辑过了
(2,914 Views)
Hi David,
Thanks for the post and I hope your well.
Pine has found a good link for you.
It actually says that SUSE 10.0 and LabVIEW 8.0 = √- The software/driver package is not certified to work with this distribution, but may work with an appropriate version of NI-KAL installed or other workarounds. Extensive user testing is recommended before deploying a system using this configuration.
Appropriate version for SUSE 10.0 is NI-KAL 1.4.
You may download various versions of NI-KAL from the NI Drivers and Updates page.NI-KAL Drivers and Updates.
Hope this is a little more detailed,
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(2,904 Views)
