Can Labview be used with SR (speech recognition) in Windows XP?
Can labview be used to convert a spoken voice into electronic text using speech recognition or can the SR application in Windows XP be setup to work within a labview application?
(4,088 Views)
you should be able to use the SpeechApi from microsoft, I am not sure about the licensing fees but I have played around with this API in the past and it works with Labview through the ActiveX interface.  I mostly used the text to speech functions however.
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(4,078 Views)
Paul,
My apologies, I inadvertently selected the wrong number when rating your reply.
Thanks for your input!
Jeff
Message Edited by jefska on 01-17-2006 02:14 PM
(4,052 Views)
were you able to implement this? I am pretty unfamiliar with APIs and activeX, and was wondering if you had a simple vi for this at this point.
thanks
(3,470 Views)
I don't know about simple VIs for this but one example of using the api is in the Control LabView through speech plug-in. You should check it out.
Jason
Wire Warrior
Behold the power of LabVIEW as my army of Roomba minions streaks across the floor!
(3,451 Views)
yes, I actually DLed this.  Not really looking for software to use, but more cause I wanna make a simply application that can use user input in terms of saying "left"/"right, or "yes"/"no" to cause an event to cause one of two events to occur.
i looked at the code.....guess I'll have too look at it longer 🙂
(3,442 Views)
