02-09-2006 12:10 PM
02-09-2006 12:49 PM
Hi:
You can group your componets using a cluster and use property nodes to make them visible/invisible. I've attached a VI that shows how to do this. Hope this helps. Robst.
| Robst - CLD |
| Using LabVIEW since version 7.0 |
02-09-2006 03:11 PM
05-25-2010 05:50 PM
I came on your post needing a similar feature: showing/hiding a bunch of controls and indicators. The cluster of controls would work as referenced by the previous poster. Just make note that if you group the items into a cluster of controls, you cannot have indicators in there. A cluster can be filled of controls or indicators, not both. What worked for me was placing the controls/indicators within a tab, and using the tab's Visible property.
Stephen McClanahan
