Can I write to Modbus I/O Server addresses without creating bound variables?
Hi all,
I'm wondering if it's possible to use the Modbus I/O Server without explicitly creating bound variables?
  • If I write a value to the bound variable at "ni.var.psp://My Computer/Slave/300001", the master can see the value.
  • The variable properties paeg says that the variable is bound to "My Computer\Slave.lvlib\ModbusSlave1\300001"
  • I deleted the bound variable and tried a few different ways to write directly to the I/O Server, but all of them gave me Error 0x8BBB0005. I tried the following:
    • ni.var.psp://My Computer/Slave/300001
    • ni.var.psp://My Computer/Slave/ModbusSlave1/300001
    • ni.var.psp://My Computer/Slave.lvlib/ModbusSlave1/300001
I also tried replacing "My Computer" with "localhost" above. No luck.
Is there anything I've missed? I'm asking because CPU usage is very high, and I thought I might be able to reduce that a bit by removing the 300 bound variables in the system.
Certified LabVIEW Developer
(4,609 Views)
 You can use the modbus library to be a modbus master or slave. This does not use bound variable. You can add a comunication loop to your code. This gives you more control of the update rate and timeouts. You can down load the library http://www.ni.com/example/29756/en/
(4,582 Views)
Hi Dave,
Thanks for the recommendation. However, I'm hoping for an I/O Server based solution. At the moment, I don't actually know if I'll even benefit from getting rid of bound variables yet, so I don't want to rewrite my code yet.
If the bound variables are indeed the culprit for my high CPU usage, and if bound variables are the only way to use I/O Server, then I'll look at the low-level Modbus VIs.
(4,570 Views)
I just noticed a typo in my original post. The paths I tried are:
  • ni.var.psp://My Computer/Slave.lvlib/300001
(4,568 Views)
Accepted by JKSH
You can use DataSocket with a path like psp:\\localhost\Slave\ModbusSlave1.400001 for read and write access.
Check out the example VI "Monitor OPC Items with DataSocket.vi" in the LabVIEW examples.
Certified LabVIEW Architect
Unless otherwise stated, all code snippets and examples provided
by me are "as is", and are free to use and modify without attribution.
(4,557 Views)
Thanks Michael! That worked perfectly.
(4,551 Views)
