Can I export VHDL from Labview FPGA?
We have a situation where existing Labview FPGA code works, but we need to embed it into an environment where we can't run Labview.  So we're considering taking the VHDL generated by Labview FPGA and porting it to another FPGA.
To do that, we need to get our hands on the VHDL output.  How does one do that?
Peter H.
PS: If could find an FPGA forum, I would post my question there...
Message 1 of 11
(10,029 Views)
Hi Peter,
There is no way to get to the VHDL generated by Labview FPGA.
Brian
Message 2 of 11
(10,021 Views)
Hi Peter
I do not think there is a easy way to see the VHDL code.
Althought the FPGA toolkit is using the VHDL as an intermediate step before binary code.
take care
Pawel
Message 3 of 11
(10,015 Views)
Hi PGH,
As Brian and Pawel indicated, there is currently no way to access the LabVIEW generated VHDL code.
Matt S.
Applications Engineering
Message 4 of 11
(9,990 Views)
I have the same question als PGH: Is it possible to export/generate VHDL-Code from LabView? But your answers are about 7 Years old, so i would like to ask if something changed in this time.
And i have another question:
If its still not possible to export VHDL-Code directly out of LabView, Labview can generate C-Code by a C-Code-Generator. Is it possible to generate C-Code out of LabView-FPGA-Projects and to transform this C-Code with translators to VHDL-Code ? I have found some news that say there exists such translators. Did National Instruments sell solutions like that oder solutions that can generate VHDL-Code in other ways?
Message 5 of 11
(8,810 Views)
Hi M.,
yes, there is a translator to C. Just call your local NI representative. Take a seat before asking for the price 😄
Message 6 of 11
(8,808 Views)
So there is still no way to generate VHDL-Code directly out of LabView ? For example to use it to develop an equalent ASIC ?
Message 7 of 11
(8,803 Views)
Are you in any way related to Incanus?
The very same question of a new member of the forum?
Message 8 of 11
(8,799 Views)
I have the same problem: I want to genrate the vhdl code from labview. Did you find a solution??
Thanks in advance.
Message 9 of 11
(7,670 Views)
I believe in newer versions of LV FPGA, this is supported. I don't know which version was the first to support it though.
http://zone.ni.com/reference/en-XX/help/371599N-01/lvfpgahelp/export_fpga_vis_howto/
Message 10 of 11
(6,607 Views)
