取消
显示结果
搜索替代
您的意思是:
Can I convert 3D image to an array of pixels in LabVIEW?
Hi all;
I am still new with labview. I has 1 question, can I convert 3D image to an array of pixels using labview?
Most of the examples I found they only convert 2D image. Hope anyone can give me some hint.
Thank You
0 项奖励
1 条消息(共 10 条)
5,320 次查看
Well, the other way around shows a 3D image (look in the example vi's)  is nothing more than a 2D array.
Now it's depending of what kind of 3D-image you have in mind. Got any data?
0 项奖励
2 条消息(共 10 条)
5,307 次查看
Hi EmcV,
Thanks for response. Actually I has 3d medical image of CT-brain scan. I want to convert this 3d image into their pixel values. How can I do that in labview?
Thank You
0 项奖励
3 条消息(共 10 条)
5,304 次查看
Without seeing the actual data it's going to be quite difficult. Can you attach such an image (datafile?).
0 项奖励
4 条消息(共 10 条)
5,302 次查看
Hi EmcV,
I attached the image. Thank You
0 项奖励
5 条消息(共 10 条)
5,300 次查看
Obviously this is just a 2D image. This is not convertible to a 3D dataset.
If you only got these images it's bad luck. If the original data is available it's a different story.
If made with a CT-scan this image is build from various slices. Might be the scanner is even able to save in 3D data.
Building a 3D dataset from a series of images is still slightly different from what you would expect. The step between images can be converted to height.
0 项奖励
6 条消息(共 10 条)
5,289 次查看
Hi EmcV,
Where can I find a 3D image? Can you give any links that provides example of 3D image? I want to distiguish between 2D and 3D array of pixels representation in labview.
0 项奖励
7 条消息(共 10 条)
5,287 次查看
look at this thread.
It has links to other threads where the 3D graphs were used.
You should also search for "gif reader" to find threads where images are read from gif files.
Ben
8 条消息(共 10 条)
5,276 次查看
@Ben,
Wow, you got a new Fan.
0 项奖励
9 条消息(共 10 条)
5,272 次查看
Hi Ben,
Thanks for the link and suggestion.
0 项奖励
10 条消息(共 10 条)
5,268 次查看
