Can I change the interface language from GER to ENG ?
I work at a company which has Labview software in German language. I'm an English-speaking person and I've learned to use labview in English therefore I'd like to know if it's possible to change the interface language from German to English.
If there is no such option, is it possible to have both English and German versions legally installed under the same license on one workstation ?
Best regards, Mikolaj Glinski
(27,607 Views)
Hi Mikolaj,
you can´t simply switch the language. You have to install an english version for it. I´m not sure if you can have an english and a german version (from same LV version) on one PC.
Mike
(27,597 Views)
Thank you.
I've looked through the licencensing information, and with my license I can apparently install LabView on 3 different workstations. Is the license tied to only one language version or can I install an English one without worries ?
Mikolaj
(27,586 Views)
Hello Mikolaj,
i recommend you to download the evaluationversion of LabVIEW and activat it with the product activation code of the german version of labview.
I hope this will help you!
Best regards
Sascha Egger
Sascha
(27,562 Views)
Accepted by topic author glina
The licence is not tied to one language, so you can install the english-version without worries.
Best regards
Sascha Egger
Sascha
(27,533 Views)
Thank you all.
(27,513 Views)
I am facing a similar problem: we have a licenced French version of Labview 7.1, yet unfortunately I do not speak French. As I understand it is OK to install an English evaluation version of Labview and activate it using our licence key - yet where can I find a Labview 7.1 evaluation version? Any assistance would be highly appreciated!
Thank you very much,
Andreas
(26,094 Views)
