Can I automatically get "This Connection is Required" on a VI's Connector Pane?
I waste a lot of time going through nearly every terminal of subVIs and selecting "This Connection is >> Required".
Is there a way to make "Required" the default, rather than "Recommended"? The "Required" state is very useful to me, since it ensures all my subVIs' terminals are wired. Tracking down unwired terminals can be very time consuming.
Message 1 of 15
(5,460 Views)
I don't think there is a way to make "required" the default for all new VIs, but you can programmatically set it for any existing VI as follows.
Open a VI reference (the target VI must be in edit mode) to the desired VI and get property ConPane, of which you get property controls[]. Now iterate through them and set them to "required" using an invoke node. See attached image of a code draft I just made. Seems to work, just add error handling etc. 🙂
Message Edited by altenbach on 06-08-2005 02:49 PM
Message 2 of 15
(5,467 Views)
That'll do, thanks 😉
Message 3 of 15
(5,444 Views)
When I pop up on the first Property Node and select "Connector Pane", I what actually shows up is "ConPane", as shown in the attached picture, where your block diagram showed "Connector Pane".
That would be fine, except I can't change it to "Read"-- the "Change to Read" item on its popup is grayed out.
Any idea what is going on here?
Message 4 of 15
(5,441 Views)
Mine is set to "Name format=long names" for clarity. Same difference in functionally. 😉
Anyway, you can just right-click directly on the ConPane entry and select "Change to read", don't right-click on the property node "header" for this.
What is your LabVIEW version? Works fine in 7.0 and 7.1, but in 6.1 I cannot change it to read. Weird!
Message Edited by altenbach on 06-08-2005 03:45 PM
Message 5 of 15
(5,436 Views)
I have LabVIEW version 7.1, and I changed the name format to long (that worked), clicked directly on that item, but I still can't set it to read.
Would you be kind enough to attach that dummy VI you built, so maybe it will fool my version of LabVIEW into thinking that property is readable?
Message 6 of 15
(5,424 Views)
Very interesting. If I create a new property node in LabVIEW 7.1 it also does not work. If I make it In 7.0, take it into 7.1 and save it, it still works :).
See attached. I tested it and it seems to work.
(Weird thing: In 7.0, I actually have two "connector pane" entries in the pulldown. One defaults to read and one defaults to write).
Message 7 of 15
(5,422 Views)
Score!
I tested your attached VI, which I cannot create in 7.1 nor 7.0 nor 6.1. But your VI sneeeeked around my lame LabVIEW versions and made it happen, thx.
Prolly another LabVIEW bug, thanks for the useful tool.
Message 8 of 15
(5,418 Views)
Hi Christian,
I could not duplicate your success with 6.1 7.0 or 7.1.
I read about a switch on the "LAVA" forum that would give you some extra (ah-hem) options. I think Jim Kring wrote up a warning connected with it.
So, maybe compare your ini file settings.
Ben
Message 10 of 15
(5,402 Views)
