Can Excel run a Labview executable?
Hello Everyone:
Can Excel run a Labview Executable?
I would like to open an Excel File, fill some data on sheet1
and then PRESS a button on the Excel sheet1.
By pressing this button, it will start running a Labview executable.
thank you all,
\\carlos in Sunnyvale, CA
(5,189 Views)
Accepted by Diego2000
A LabVIEW executable is an executable like any other executable. As long as the LabVIEW Run-Time Engine is installed you can call it from within an Excel macro using the Shell() command as in Call Shell(executable).
(EDIT: Accidentally clicked Post before I had finished)
OR, are you trying to call it using ActiveX with LabVIEW as an ActiveX server?
Message Edited by smercurio_fc on 02-10-2010 03:06 PM
(5,170 Views)
I believe this questions belongs more to some kind of MS Office software (specifically Excel), than to this forum. I think you should assing a macro to the button and you should call the exe through the macro command.
The macro command should look like this:
Sub LabVIEW()
Dim RetVal
RetVal = Shell("C:\Program Files\National Instruments\LabVIEW 2009\LabVIEW.exe", 1)
End Sub
Remember, you must have macros enabled.
Message Edited by Giedrius.S on 02-10-2010 11:08 PM
While evaluating my code please have in mind that I am a LV novice. Therefore sometimes my code might violate some coding rules that I have to learn about myself. But how else could I do that... 🙂
Chart zoom with "Mouse Over" effect
(5,163 Views)
Yes you can - in fact there's an example that ships with LV that does exactly what you are wanting to do.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(5,153 Views)
Thank you all:
Mike, you mentioned that LV shipps with example?
What is the name of the example?
thank you,
\\carlos
(5,126 Views)
The example that Mike is referring to is a workbook called "freqresp.xls" that is in the <LabVIEW>\examples\comm folder. This uses LabVIEW as an ActiveX Server, which is why I was asking whether you were looking to just launch a LabVIEW app that you built or whether you wanted to control LabVIEW using the LabVIEW ActiveX Server method.
(5,109 Views)
Thank you SMercurio:
I just wanted to run a Labview application.
Now, I would like to minimize it or make the Labview application invisible...and quit after the app runs...
Thanks for your response, I'll look at freqresp.xls
\\carlos
(5,107 Views)
